power port fuse on stelvio
anyone know where it is on a stelvio ?
Hi,
I blew mine too. The fuse is in the block under the seat near the tank on the RH side. The actual fuse is clearly identified in the wiring diagram but if you don’t have one to hand simply pull out the 5 amp fuses and hold them up to the light until you find the blown one.
Good luck,
Richard
