Hi all.
I’ve had to admit I need to cut down on the number of my ‘Project’ Bikes I was planning to work on in my retirement. ![]()
One of the ‘casualties’ is the 2012 8V Norge GT that I picked up a couple of years ago.
It was a ‘stolen-recovered’ salvage Bike, which I wanted for two reasons, well three, but it being a Guzzi goes without saying obviously!
1. I wanted to swap it’s Gearbox into my Stelvio, for the slightly higher Gear Ratio in top.
2. It’s a ‘Roller’ Engine.
It started fine and ran nicely when I got it, it’s on 47,700 miles.
Mechanically fairly OK, Plastics not so good, some damaged, some missing.
A couple of the Rear Wheel’s Disc Mounting holes have been damaged in an attempt to remove seized Bolts by a previous owner, should be repairable by welding, machining, re-drilling and tapping, or they can be picked up second-hand reasonably cheaply.
Has two original Factory Keys.
Would like to see it kept running and on the road in some form (few enough still out there) rather than broken for spares, but I understand that’s not always a realistic option.
I don’t have the time or the space to dismantle any of it, need it gone as a ‘whole’ Bike now.
Located nr Slough, S. Bucks.
Message me directly if interested.
Thanks.
