Hi
My 2004 California EV had developed rapidly flashig indicators (both front and rear, left and right). I have checked the connections to all the indicators and WD40’d them. But actually the flashing has speeded up
Does anyone have any ideas what might be the cause.
Try a new Relay The most probable reason.
Regards, Nik
Thanks… just ordered one ![]()
On my LMIV its often caused by a poor earth.
LED bulbs can do this as well.
I have bought a new flasher which worked for a while but then speeded up again. So I have asked my son who is an electronics expert to design me an electronic flashing relay.
I bought a new flasher which worked for a while but then speeded up again. So I have asked my son who is an electronics expert to design me an electronic flashing relay.
Good evening, just fitted a new one to my '95 Cailifornia 1100i, it was doing similar and the relay was definitely tired, so I got a ‘tuneable’ one off Amazon, can be dialled to your desired flash rate to work with the like of LEDs and so on. Fitted in moments, works great!
Hope that helps.
Thanks Jeff
