Does anyone know where I can get paddock stand bobbins for the rear axle on a tonti frame racer? I suppose it might even replace the axle altogether if there were an extended axle available.
You could try a small (local) engineering firm.
Not too difficult to know up on a lathe if you have the design/dimensions.
Best of luck
I bought mine from Harris engineering.
OK that’s great, thanks. I am maybe thinking of getting a complete axle turned with integral bobbins, so will update if so.
How did the Harris bobbins fit on though?
Cheers Steve Mr Noisy2014-01-19 21:34:32
A friend welded in some inserts so I could fit them.
