Any advice on how to open petrol cap with no key. If I drill will swarf drop into tank or be retained inside cap?
If you only drill out the Barrel the swarf wont get into the tank. Or you could use a large screwdriver with some brute force!!!
Which type of cap? If it is the flip up one from the 80’s, can you pull out the front pivot pin?
