I am intending to replace my swing arm bearings as they weren’t really lubricated and have brinelled. What I am wondering is that there are a couple of slots in the frame where the bearing cups are located which I assume are used to extract the cups.
Does anyone know of what tool is suitable or what method works to knock them out?
I don’t think it matters but it is a 1200 sport 8v
Solved, needed to use a pry bar with the sharp edge on the bearing cup inside and then used a bar that passed through the frame onto the pry bar and knocked out with a hammer. Two person job but took couple of minutes to do.
