Fitted a Roadlok today
A spacers and 80mm M8 bolts
May I ask where you got this from? I can see a USA site but not a U.K. one
Here’s the link to the UK site
The spacers are supposed to be lettered but they weren’t on mine so just put them on a flat surface and you can work out which is A,B,C etc. there is a card that tells you the sizes and is used to measure the distance when the existing bolt is unthreaded , there are videos on youtube showing that. It’s a critical part of fitting.
What are you fitting it on ?
I had one on another make and found the lock was always difficult to use, I put some graphite (please excuse spelling) and it transformed it…
I will be fitting to my new V100 Mandello ![]()
Excellent.
It’s really straight forward once you have the measurement with the top caliper bolt unthreaded then pushed back in against the threads.
Yes it was very straight-forward to fit!
glad you got it sorted
