After 38 years on the road, my S3 needs its Brembo front master cylinder overhauling. In the Brembo overhaul kit, there’s the clip that holds all the innards in, as it were. The old one on mine was knackered.
What’s the best way to insert this into its recess? I was thinking a long socket that fits, to drift it into place. Anyone done this?italianmotor2013-04-29 19:49:18
yes you need a long thin walled socket, can’t remember if its a 13 or
14mm one needed, I seem to remember that one of the brake master
cylinders needs a 13mm and the other needs a 14mm one,just checked it over and the front handlebar cylinder requires a 13mm long thin walled socket but the behind the side panel linked brakes cyclinder requires a 14 mm long thin walled socket
Managed to to tap it in with a SnapOn 3/8 13mm long socket and seemed to go in pretty easily. The instructions from Brembo that come with the overhaul kit only have diagrams of the rear master cylinder, and you need a microscope to read them, so I didn’t bother…italianmotor2013-05-02 21:39:51
