Hi,
Can anyone recommend a vehicle upholstery company to re cover the saddle on my SP1000?
Peterborough/Huntingdon area.
Thanks,
Alan
Hi,
Thanks,
Alan
What do you want - repro of original or just something functional or decorative?
The profile is lower than the ones normally found, I want it to follow the original profile and shape. Don’t want anything fancy, just functional.
I had my G5 seat recovered by Geoff Bennett in Newton Abbot. He offered lots of options, from the purely functional to the ultra-bling. In the end I went for a combination of two vinyl textures and colour-matched thread detailing. He did a superb job and charged peanuts.
Looks great, it goes together well, I’ll give him a call.
I used a seat cover from a V50 for my 1978 Spada and it was an exact match. The guy that made the cover just left a bit of extra vinyl on the front to form the bit that goes up onto the tank. The cover was made by Bob the seat but he has since retired and his business has been taken over by someone else. They don’t list Guzzi but apparently have all the press frames from Bob so should be able to do one if you ask.
This is the new seat cover, I had it fitted by G A Wells in Shepshed near Loughborough.
I always use leightons they were in Birmingham but I see they are now in Aldridge 01922 277 550 regards Jem Starkey
Thanks, I’m looking into carriage cost as there is not much going in my area.
That is the seat shape that I want, with the wrap around the tank. Do you have a contact for the company that you mention?
I shall contact Saddle Craft, they look promising too.
Thanks.
That seat style is correct for the early Spada models. The later Spada NT may be different.
These are the details for the company that fitted the cover for me.
G A Wells & Sons
9 Hall Croft, Shepshed
Loughborough
LE12 9AN
Telephone: 01509 504700
There is a very good upholstery place in Baldock Herts just down the road from you, does a lot of custom work, sorry can’t recall the name but a quick search on Google should bring it up
Have you tried contacting Moto Stitch in Northborough? I’ve had no dealings with them, so can’t actually recommend them, they are very local to Peterborough though.
Good evening, Don. I came across your post while browsing seat upgrade options for my 1980 Spada - but was immediately distracted by how PERFECT your rear rack looks! I’ve been hunting far + wide for something precisely like that (leaving the original grab rail in situ - kind of important as it incorporates the seat lugs) - but no joy. I’ve even shortlisted some local fabricators to quote for replacing the grab rail and incorporating a rear rack in stainless steel. That would be proper pricey, no doubt - so can you share any info about your rack? Model number/name, where sourced from, etc? Or (let me guess) did it “come with the bike”? - that would be just my luck. Fingers crossed then… Oh, and does it rely on the pannier frames for support? Doesn’t appear so in your photo - seems to attach via shock absorber top bolt and rear of frame - is that correct? Cheers, Paul.
