How do you cancel spanner icon on V7 special on 2022 model if you do your own maintainance?
I think only a dealer can reset the spanner icon.
That is my understanding too.
That was my thinking too, it needs to be plugged into the dealer’s machine to reset the electrickery and remove the spanner light. Call your nearest dealer and getting it done for free, as it won’t take them long, worth a try anyway…
If you do own maintainance and spanner is showing once you have the mot, could it fail.
New MOT failure surrounds warning icons flashing on screen.
Where in the country are you Rippers?
Hi Chris I am in South Cheshire/Staffordshire
Hi Rippers… I used to own a 2015 V7II, and serviced it myself, ( when out of warranty)… There was only four easy steps to cancel “maint” when it appeared in the LCD display in the speedo … Does your dash consist of two clocks, and two small chrome buttons between them ? … If yes, then we may be in sight of a solution… Regards, Tony
No buttons on dash of V7 850 Special - as been said, dealer tool only.
Does GuzziDiag not work on this bike?
Unfortunately no, needs OBD2 reader that is canbus compatible.
Last I heard, the Guzzidiag people will have to write a new program.
I had same issue with spanner coming on as I did yearly service with dealer. However milage was lower and had not past the numbers needed for spanner to come on. The problem from the dealer was that unless i had had it serviced and logged with a Guzzi dealer the stated they would not clear the spanner symbol. As i has to had to go to a different guzzi dealer as my closest one had gone bust. They wanted paper proof of the previous service taking place. Bit worrying really that they are holding monopoly like that. This was on V7 850 E5 2021 model.
I’ve got no chance then as I did everything myself.
You can buy a tool that does it and checks the system, it works but it’s £400 , That’s less the cost of 2 shit dealer services so I think it’s worth it
Any idea where to buy this device from?
I would also be interested in this, wonder if we could get a group buy discount ?
I bought it from Duonix in Germany, good to deal with and will answer your queries. Www.duonix.de
Info@duonix.de
Gino
I’m having trouble finding that exact page. I’ve clicked on ‘Moto Guzzi’ but the list is different. (?)
