Hi, is it possible to get the plastic side panels of my Targa replicated or repaired if damaged?
I repaired the side panels on my V65c using a gas soldering iron and a strand of heavy electric copper cable bent into a few s bends.
I first melted the plastic at each end of the break in the panel to keep it together making sure the profile was correct then placed the copper cable across the break and slowly melted the copper into the break , using a bit of black cable tie as a welding rod covered the copper over and welded it onto both sides of the break it is still holding after about two years.
