I found a mid-mount sidestand bracket on eBay a few weeks ago, and got round to fitting it on my Spada today. I think it came from a 1000S, but maybe the same as others. Bracket fits OK, but the pivot position is lower so the existing stand is too long. Looks like it needs to be about 25-30mm shorter.
Has anyone got one they don’t need, or can measure the length for me? I can perhaps cut my stand down and re-weld the foot on.
Could you not alter the angle of the bracket with a vice and hammer. Did this on mine and it did the job fine. Don-Spada suggested it to me as I had no access to welding equipment and needed the bike back on the road.
No need for cutting & welding, and that’s a bit drastic if you get it wrong. I had same problem with mid mount side stand being too long for a Mk4 le mans (with 16 inch front end), just heat it up till cherry red and then bend the tube over. That way you can do in stages until its just right
My 850T didn’t have a side stand when I bought it, so I considered my options. in the end I thought I would try modifying a Royal Enfield Bullet stand as they are cheap new on eBay and it worked out really quite well.
