Small block clutch
I am replacing my Breva 750 clutch with one from a later V9 hoping for a much lighter pull, idea came from somebody on here. My clutch pushrod seal is leaking gear oil into the clutch housing. Does anyone know if replacing the small block clutch push rod seal require transmission disassembly?? In all the years I’ve worked on Guzzis I can’t remember doing even one.
Brian
I measured the original clutch pull at @ 25 lbs, the new clutch at @ 11 lbs.
      HOLY WA BATMAN!!!!!
Brian
