Speedo conversion kph to mph advice
Hi
I’ve just imported an NTX650 and need to convert the speedo to mph from kph.
Has anyone any experience or advice on this ? Not sure whether to fit a converter or just change the dial. Also can anyone recommend a good supplier for the parts ?
TimÂ
You could try Guzzibits praps…I run my kilometre clock bikes with mph numbers on top of the glass…
That was my other option, wasn’t sure how valid they were for MOT, presumably you’ve never had any issues ?
Thanks for that reply
Â
I run my lemon on a kph clock with slips of red tape to mark 30-70 then 100-140 mph.
Never had a problem with MoT’s since 1987.
There used to be a company that did MPH decals to fit onto various sizes of clock, don’t know if they are still around.
Kate are these proprietary stick on numbers? because this is what IN saw on a Bellagio at the guzzufest and I want to find where to get these from
I got mine from The Range wud you believe…in the Craft section…
I have a kph speedo on my T3, and leave it as is. No problem with MOT’s and you soon get used to the mental conversion to mph
I just stick a Mountain Bike type speedo on mine as back up, £8 from Tesco , there accurate and have a clock, trip, etc.
