Came off my V11 in September, got the parts required to get it back up and running.
Replaced the gear lever as my big toe snapped the other as well as me toe !! Took a couple of hours was a right pain in the a@@@.
Before moving on I thought I’d see if it would at least start .
Alas NO, had to use a jump pack. Fuel pump made noises clicking from relays etc.
Pressed the starter bike caught briefly, will only start (ish) if throttle held open and starter button kept in and only a few seconds at best.
The exhausts are heating up though if that helps ![]()
Any suggestions will be gratefully received
