I was riding my 2011Stelvio on Saturday on the A12 in the heat of the day and pulled off
as the traffic was solid and headed home via back roads. I looked at my dash to check my speed and this is what I saw
The fuel gauge had swapped to the right and the speed was fixed at “FE”. Looking at it now it appears that the whole display was mirrored. I turned off the ignition and after a few seconds the screen went blank, Started the bike again and all was back to normal. Very strange!
Anyone else had strangeness with their display?
I had something similar happen on my 2012 Stelvio. LCD locking up and once had it flip. Asked for help on a Facebook group and it was suggested that I check the spark plug caps, which I did. Found one of the cables inner wire broke at the cap end. Replaced both caps with NGK SD05F and have not had a repeat of the problem.
Turning yout picture upside down, the numbers seem to be trying to make ‘35’.
And bottom right is ‘+52 °C’, looking almost perfect.
Plug caps fixed the same fault on mine. MG genuine are crazy money if you can find any, Twiggers in Loughbrough sorted me out with some NGK ones.
