Afternoon all has anyone had any problems with their Stelvio blowing the auxiliary fuse “B” on start up its a 2010 non abs model.It’s doesn’t always happen but when it does I can go through 2/3 fuses before it starts again hope someone can point me in the right direction cheers Tim
Don’t know if it’s the same fuse, but I’ve had the 30amp headlamp fuse blow, which also feeds the heated grips, aux light, headlight and alternator. 2014 NTX.
A fairly common problem,as the 5 pin headlight relay cannot cope with the extra load.
Cured by fitting a Bosch relay. part no. 0-332-209-151
Worth checking the headlamp connectors as these have been known to burn out.
