Stelvio (new 25 reg) oil leak
Has anyone had this leak fixed under warranty, as mine has showed itself with only two days from collecting.
I’ve had a look it seems to be coming from an oil temp/pressure sensor in-between the two cylinders green sensor, leaking from the centre through the pins and in turn through the connector.
