Simple question.
I just got the 1100 California 3 - the 1994 carbed model.
What would you suggest would be the best oils to use in this machine?
When I had the 950 a miillion years ago, I used Morris 10/40 in the engine and Castrol EP80/90 in the gearbox.
I think I also used the EP80/90 in the shaft too, but its going back a few years.
The thing is that I have read a few places that 20/50 should be used , and various other weird suggestions for the Gearbox and the Shaft?
What do you suggest?
Many thanks.
I always follow the Guzzi recommended grades on my bikes which is 20/50 in the main engine and EP90 gear oil in the gearbox and rear bevel box (with a bit of Molyslip added). Your bike is a bit newer than mine so the spec may have changed.
You can find the user manual here (along with parts books, wiring diagrams etc)
https://www.guzzitek.org/gb/accueil_gb.htm
those oils are still available. if you thought they did a good job then, and can obtain them, use them.
or: others will tell you how synthetic oils are the new black.
MGCGB have an ‘arrangement’ with Opie Oils, I believe.
Thank you for that bud.
I have not long found the old Haynes manual for it… I did also have a workshop manual, but thats long gone.
I used to use MORRIS 10/40 car oil in the 950, not even use Motorcycle oil.
I guess that is the slow revving of the Guzzi makes it better for that oil perhaps?
Anyway, I will get whatever I can, so thanks for the link!
It doesn’t need a motorcycle specific oil as it doesn’t lubricate the clutch, I normally use the Halfords classic 20/50.
