Posted by Eight valve Eagle in response to qn how to swap Stelvio dash from MPH to KPM
hi shifty
yes you need to go into diagnostics entering the two codes first first one will be user code which If it has not been set then is 5 zero’s next will be the dealer access code which for stelvio is 10695 then you will be able to access and change display from miles to kilometers
regards keith
It was done and succesful
