Spoke nipples all polished. Rim arrived from Italy. So this afternoon I threaded up the rear wheel which is a piece of cake on a Tonti Guzzi as the spoke holes in the hub are actually tunnels, so when you push the spoke through it automatically points to the right hole in the rim. It even has the holes higher and lower so it is obvious which spoke lies over or under its partner. Tomorrow is the tightening and truing up the wheel. I am actually looking forward to it!
All laced up and running true! As with most first time ventures it is a learning curve, but once figured out, no problem!
