So last year, running Blue hard coming back from the Scottish the old girl started dropping a cylinder as I was nearing Scotch Corner. I limped into the services there and swapped the plugs out as that was pretty much all I could do. That got me home. It was on my mind that it could be a coil problem and that I would swap them out for new in due course.
So along with all of the clutch bits I bought for fitment over this winter I also ordered new coils. I allowed myself to be convinced that super duper Dyna coils were the things I needed.
Now on Blue the coils are mounted under the tanks rather than inboard of a side panel, and it is all very tight down there. And the Dynas have very different fixings, and the HT lead outputs are to one side. I’m not sure that I have the strength right now to try and work out how best to mount these and then fabricate some mounts.
Has anyone else here faced up to this and found an easy solution?
