The headlamp reflector on my 78 T3 was shot so I bought a replacement Ring 7" light from this lot on fleabay HERE
The unit duly arrived and fits nicely, except that the light has 3 flat loops equally spaced around the rim in place of the screw and captive nut type of arrangement of the old lamp.
=105113868&filters[recent">=1&sort=1&o=1">As in this piccy here=105113868&filters[recent">=1&sort=1&o=1">As in this picture
So, my Q is, have any of you mocked anything up , or have any suggestions as to allow the adjusters to still work?
Or
Do I just ditch the adjusters and crop the screws, and leave them in place as dummies?
Thanks for looking
I replaced the headlight lens and reflector in my T3, and had to do away with the right-left adjuster. I just put in a short screw and nut to plug the hole in the headlight rim. It did need a bit of pushing to sort out alignment, but nothing difficult, and I got there in the end.
Edit - just re-read your post. The reflector should be held in the rim with w clips - you didn’t mention these. Have you got some?fen tractor2013-12-15 20:34:18
Thanks for a swift response guys.
I’ve me W clips, haven’t seen those so ill go back and have a look at the parts list, unless you have piccies to hand.
I’ll forgo the adjusters as advised, thanks
I just realised that I also need a rubber gasket, the 7" dia one which nestles between the glass and the rim, any thoughts on where I can get one.
Or is it a silicone DIY jobbie?
Thanks again, Brian
I didn’t bother with a gasket, and it doesn’t seem to be a problem. If no-one else responds, I’ll pull the headlight out to take a photo of the w clips, but there should have been some in place already…?
And this is inside the rim (ooer), showing the back of the dummy adjuster and one of the w clips (I use 4 in total):
If you tried to make your own w clips, you would need something like piano wire, and it would be pretty fiddly to get it right. They are not expensive to buy, so I personally wouldn’t take the risk.
