T3 with oil blowing oil out of breather pipe
I’ve had a set of 950 barrels on my T3 for probably 14 years. Last summer the engine started pushing out a lot of oil out the breather hose and black spark plugs and a compression test said it was time for a strip down. barrels off, and the measurement of the bores said they were well out of wear tolerance, The barrels that I’d fitted after the original Nikasil one wore out were 2nd hand SP1000 (the barrel spigots had to have 0.74mm machined off to fit the 850 crankcases) and had steel liners, so no problem! I’ll get some oversized rings, pistons and get a rebore…1st Oversized rings obtained, but merde! No first oversize pistons available.. I investigated getting some custom pistons manufactured by a piston specialists in Cambridge, but adding the cost of a rebore, gudgeon pins . circlips, it looked financially more beneficial to obtain a set of Gilardoni barrels with high comp pistons, rings and all parts required, so they were obtained and fitted. Whilst I had the heads off, they were refurbished with new inlet valves and a tidy up of the ports. Everything was reassembled, the points ignition unit was cleaned and fettled, and apart from a drama with a seized solenoid causing a runaway starter motor, it started and ran perfectly but after one test ride I had to replace the stator as that had shorted out, and fitted an Electrex World Regulator/rectifier, and then began the bedding in process.
I’ve been riding to work, which is a 80 mile round trip on A roads, single and dual carriageway, and I’ve covered over 600 miles, so far, on the new barrels, gradually increasing the speed as I’ve clocked up the miles.
The issue that has come up, is that there is a small amount of oil, enough to show on the L/H side of the tyre, being expelled from the engine breather. Last year I fitted a sump extension with external filter (not the one sold by Gutsibits) with a sump baffle plate that came with it, and I’m wondering if that is that may be the cause of the oil being expelled?
Check the engine breathing system as if that gets blocked, it can pump oil back up the vent return and out through the drain pipe.
What sort of breather system is on your bike?
Thanks for the response, Don. My T3 has breather hoses from both cam covers which connect to a chamber which sits just to the rear of the left hand cylinder, which itself is connected by a large diameter hose stub to the crankcase. A breather tube then runs from the chamber, downbehind the gearbox and terminates above the centre stand.
i don’t have an answer for you, as such, but I can share that I had a T3 go through a period of showing apparent disgust at having oil put inside it. with the help of somebody who knew what they were doing, and a fatter wallet than I have today, I tried; a sump extension, new barrels and pistons, checks on valves, different oils, etc. etc. Never did completely cure it, or find out why it happened intermittently, sometimes covering the back wheel. Eventually it just got bored with antagonising me I think, but I did end up with a small overflow bottle permanently attached to the end of the overflow pipe. I don’t want to open the whole oil debate, but one thing I discovered was that my T3 was less prone to dumping oil all over the place when I used a “traditional” mineral oil of the recommended weight.
edit: should perhaps mention that my T3 was set up with K&N filters and the “le mans type” breather box.
Check the “Top Hat” valve that sits in the mouth of the crancase pipe/hose
It sounds like yours has a LeMans style breather box fitted, as most do when people fit K & N type filters. This solution is usually very good.
I would recommend pulling the box off and as Mr P suggests, check the top hat valve that sits immediately below it in the crankcase vent hole. The ball can stick over time. The breather box may also have a flapper valve inside the larger inlet, these can also stick.
If the vent gets blocked due to a sticky ball valve or flap, then the crankcases can pressurise & oil can be forced back up the smaller return pipe from the breather box (this is the smaller pipe from the breather to the bell housing)
IIRC on my LeMan, there’s three breathers: one from each tappet case and then a bigger one from the crankcase. On the T3, I think the crankcase one goes through a fire trap into the inlet manifold upstream of the cylinder air filter.
Which one of these is it that is leaking oil?
Does sound like the old Le Mans collector box, I’ve used these too, if it is the same, there are 5 hoses, 2 x rocker boxes, 1 x large crankcase breather hose (which may or may not include a top hat ball valve in it), 1 x small drain return to sump, and 1 x vent to atmosphere. For some years I had an extension on the vent hose that was routed around the left edge of rear mudguard and ended just in front of the number plate. Never lost a drop with that set-up. Later I rebuilt it all again and reverted to the normal length shorter vent hose ending behind gearbox, and then I had the odd trouble with oil loss. Most memorable was dumping nearly 2 litres on the M6 coming home from Scotland (due to prolonged periods of constant 4,000 - 5,000 rpm, or so I assumed). Albeit was all new parts, I had it all apart (in a Travelodge car park) again looking for a fault. There was nothing wrong with it. The ‘flapper valve’ in the box was disabled and the ball valve was new and correct (I wondered if the clip had come out and the ball escaped). The only real difference I could see was it didn’t have the vent hose extension to back of rear mudguard, that I’d had before. I never got to the bottom of it because there were other issues needed sorting and then I moved house and had to down-size, so had to part with two motorbikes.
I do remember reading recently that the end of the sump return pipe in the sump must be below the oil level. I also had a sump extension on my LM1, but only put in the same oil quantity, so the level probably was below. If you have an extension the simple thing to do is add a bit of hose to the metal sump drain tube to make it reach and dip below the oil level. However I am/was not able to try this out with mine so can’t verify.
That’s great advice about the length of the sump return pipe. I’m having the sump off over the weekend, and will check the length of the return pipe.
I’ll be working through the breather system at the weekend.
I have completely the opposite memory (courtesy either Dave Richardson or Amadeo Castellani - I really can’t remember who it was). The idea of the sump extension was to lift the crankshaft above the oil level to reduce vibration caused by the crank webs hitting the oil and to allow the engine to spin up faster (yeah, right). Also, increasing the crankcase volume reduces the oil churn caused by the crank webs smacking the oil which, in turn, reduces the amount of froth being spat out of the breather. You don’t lose the splash feed to the pistons because the crank webs spinning close to the oil level will still suck up oil by their wind of passing.
There’s another version of the sump extension called a ‘windage plate’ which effectively shuts off most of the oil surface from the crank webs bar for a small area directly below the webs when they are at their furthest travel point downwards. Swinging past the hole in the plate sucks up oil and throws it under the pistons. The idea of the plate is to prevent the oil from sloshing when the bike is thrown around. Good on racetracks, but not a great deal of use on the road.
Thanks for the reply. My T3 has always run on aftermarket air filters, and the filter set up it has now, is a K&N dual inlet filter, and the same ‘le Mans type’ breather box. The oil I’ve always run the bike on is Morris 20/50 mineral oil. I’m just going to have to work through all the possibilities.
One benefit of the extension I have is that it has moved the oil filter to the outside of the sump and therefore easy to change. I understood the purpose of moving the oil surface away from the crank, but also that there is an increase in sump capacity. I’ll be removing the sump plate.
generally this is not the case. the same amount of oil is used, which requires a change to the dip tube/marker
IIRC (if!) the minimum level of the standard dipstick indicates full oil with an extended sump. Someone else will need to cross-check that because all three of my engines are currently sitting on the bench waiting for frames and wheels…
i’d say that is an unsafe assumption. is your dipstick the same length as mine? the ONLY way to be sure is to fill the sump with the right amount of oil and note the level on your own dipstick, on the stand on a flat surface. but hey… your engine! you go with that if you like :laughing:
Mine are standard brass-capped dipsticks and do vary in length by a couple of mm and that method works for me, but you are dead right on one thing - check with a sump refilled from dry with a measured amount of oil :saluting_face:
That’s an misapprehension on my part. Thanks for the advice.
Yes absolutely. I had the extension for many years - in fact I’m sure the bike came with it when I bought it - nevertheless, it lost nearly 2 litres on that day returning from Scotland on the M6. I cannot explain how or why.
Yes it does. But below minimum is then, no oil showing at all…
