Resurrection of cali 111,
got hold of a Rough 91 model it’s stood for at least 6yrs in less than Ideal conditions, dropped the oil, no emulsification, Â no bits of metal…result it’s in better nick inside than out, converted it to points, Â (I reckon ignition failure consigned it to it’s fate), Â fresh oil, cleaned out the carbs battery on and the beast livesÂ
Overhauled the brakes today, Â goes and stops.
Any recommendations for tank sealant?
Phil
We use this at work…(http://www.classicbikes.co.uk)…
Cheers Kate
POR 15 from Frosts.
I would use nothing else
Why do you think you want tank sealant?
Unless it’s leaking of course. ![]()
Tank is in original+rough condition outside, Â inside it looks like it’s been dry for years sort of white deposits peppered with rust, I’ve got the carbs cleaned out so I reckon keep the original+rough appearance but seal it to be on the safe side.
