Does a RH cylinder head from a Nevada 750 fit the Targa?
From different fora, I know the heads may differ with position of spark plug thread, but re cylinder, they should be the same. Just try to match selection, stamped on the top fin - A, B or C. If you have a choice at all… And cylinders, contrary to heads, are interchangeable, no difference LH or RH.
Thank you adamigo, very interesting.
