Hi,Anyone know the correct routing for the throttle cables for a Lemans 3.I am having my normal cables sent off to venhill to have some new ones made so I have gone back to standard setup and just want to check the route they take.Thanks.
Hi Eddie, my original LM3 had the 2 cables exit the throttle via the 2 right angle alloy tubes with adjusters, went round the front of the steering head and under the tank front opening, followed the top of the lower spine frame tubes through the rubber supports and dropped onto the carbs via the cut off section of the tank just behind the fuel taps. Hope this helps.Cheers, Gerry.
