Throttle Replacement
I need to replace my throttle, will I need to recalibrate the new one or is it a case of just plug the new one in?
I have never tried this myself.
But
I have heard that e5 and e5+ generally take the a throttle without recalibration, some e4 can be a problem.
Ok, thanks.
Yes it’s plug and play at least it is on an E4 bike. I’ve gone standard to heated ( the throttle worked fine but did need recalibration later as the cruise control was too sensitive to being knocked off), back to standard briefly then a further set of heated grips fitted. These subsequent changes needed no recalibration.
