Tonti Gearbox repair
Sorry if this in the incorrect place Its my first post, Is there anyone in Bude that repairs/re shims Tonti 5 speed gearbox’s, I recall speaking to someone I think called John who could offer this but I cant find his details now, I know its a long shot and I may be mistaken but I thought its worth an ask as my friend is heading up to Bude and has offered to drop it off for me thanks Joe
Hello Joe and welcome to the forum. I am not from the West Country so can’t help you with your search, but there are plenty of members in the area that may well be able to help you.
Best wishes Chris
Depending on how competent you feel that you are, it is not a bad job to do. I stripped and rebuilt my gearbox a few years ago and did the shimming. To be honest, I didn’t notice any difference after the work. What is making you think that yours needs shimming?
There is a very good guide to the procedure here
https://www.thisoldtractor.com/guzzitech.dk/pdf/gearbox-shim-pete-roper-new-tools.pdf
or here. …
I’m not aware of anyone in Bude, but there is a Guzzi guy in Somerset. https://www.mikerdec.com/
Thankyou for the info, the gearbox is from a V7 sport(I think) and I want to change the back of the box as it has an extra bracket on it that my bike doesn’t have, its like an extra lower mount. The new case end I have looks like it fits OK but want it set up right and I know this can effect the shimming . If i’m feeling brave I may have a look at doing it myself. thanks Joe
Sounds like it might be an early Tonti box. Those fitted with a rear drum brake had a “crossover” shaft that (I presume) ran through a tunnel in the rear of the gearbox casting. Others may know for sure. It’s your bike but one option is to not worry about it unless their is an operational issue.
Barry is nearly correct, my 1974 850T had a factory right hand brake and left hand gear change, these were crossed over from earlier models by two shafts (sprayed silver Hammerite on the photos below) carrying the two pedals these are much higher than the galleries in the gearbox. I have since swapped them back, as I was also riding a Triumph at the time and having the controls different on the two bikes was confusing especially if you wanted to stop quickly! Not a problem on the Guzzi because if I stamped on the gear pedal the back end would lock up anyway!
As you can see the shafts do not pass through the other gallery in the gearbox casing. but are carried on triangular plates either side of the frame, the brake shaft has splined ends and the gear shaft sits in cups at each end. I had to cut and shut the gear shaft to swap the lever to the ball joint that selects the gears but the brake shaft was just a swap of the pedal and clamp from side to side. I believe the second gallery was carried over from an earlier model possibly a V7 or from a loop frame bike before 1974?
Chris - As I remember it was the easiest way to comply with the US federal regulations that insisted on a leftside gear change and, amongst other things, a grab strap across the seat. The gearbox was redesigned later for a leftside change and five speeds.
The gallery below the gearbox is just a bit of history, like the castings in the crankcase between the barrels where the alternator used to sit on earlier V7s. These are not an issue to using your bike, but a reminder of it’s evolution!
