I found the list of settings these are for the V1000/G5/Convert/T3/Le Mans /850-1000cc bikes.
Bolts & Studs Cyl Head to Crankcase … 29-30 ft lbs
Spark Plugs 14-21 ft lbs
Cap Screw oil mist recovery pipe (dia 12x1.5mm) 29 ft lbs
Self Locking nut con-rod caps securing bolts …33-34 ft lbs
Bolt rocker pin securing 4.2-4.5 ft lbs
Bolt flywheel to crankshaft 30 ft lbs
Nut gear to camshaft 108 ft lbs
Screws intake pipe 14 ft lbs
Cap screw oil delivery pipe to cyl head (8x1.25mm) 10.5-12 ft lbs
Nut front & rear engine securing studs to frame 57 ft lbs
Nut layshaft securing 115-130 ft lbs
Oil filler plug on gearbox and rear drive box 21 ft lbs
Oil level and drain plugs, gear box and rear drive box 18 ft lbs
Safety nut layshaft 50-57 ft lbs
Nut bearing to bevel pinion 130-145 ft lbs
Screw crown wheel to hollow spindle 29-30 ft lbs
Bolts cradle to frame securing 57 ft lbs
Nut cradle to frame securing screws 57 ft lbs
Cap nuts, swing arm spindle 57 ft lbs
Nuts drive box to swing arm 25 ft lbs
Top plugs front forks 87-108 ft lbs
Nut front and rear spindle 100-108 ft lbs
Bush steering lock 122-130 ft lbs
Standard settings…
6mm screws and nuts 4.5-8 ft lbs
8mm Screws and nuts 18-21 ft lbs
10mm screws and nuts 33-37 ft lbs
tttthats all folks I hope it may be of use to some one
NB 850 Dennis the tourque settings for the flywheel bolts are 30 ft lbs and they are high tension bolts
“The older I get, the better I was!”
Leics guzzibear2012-06-18 21:06:19
