Hi
I need transmission bearings for my Stornello sport. Does anyone know of a company that would stock them.
Cheers Syrup Head
Hi Graham. What do you mean by transmission bearings? I assume you mean for the gearbx etc. I replaced all the bearings in my Turismo engine and they weren’t cheap, I think one bearing was £65.
Most of the Stornello engine bearings are quite narrow 9, 10 & 11mm width. They are available from most decent bearing stockists. Simply Bearings are a good start if you don’t have a local shop. I think mine came from Leicester Bearings.
Hi Don yes the bearings for the gearbox and Kickstarter shaft. I have tried local bearing suppliers without success .I will look further afield.
Cheers Graham.
Essex Bearings in Hall Road, Maldon have always met my needs, I take in the old bearing, they measure it and sell me a replacement. Excellent service in my opinion, I am not connected to this firm in any other way than being a satisfied customer!
If you have the engine apart, are you aware of how to set up the gearbox correctly? Many people get it wrong. Have a look at the service sheet that explains the proceedure Available from my DropBox files…
Hi Chris
Thanks for your reply i will be contacting essex bearings and will go over to Maldon next week.
Thanks also Don for the info concerning the correct way to assemble the gearcluster etc.
Cheers Graham.
Hi Chris,950 I received the bearings for my Stornello engine from Maldon Bearings yesterday . Thanks for the recommendation .
Cheers Graham.
No problem, they are called Essex Bearings, just in case anyone else tris to search the interweb for them
