Uploading photos
Easy to add pictures … click the upload button!
great tip @rogershuff - and if you’re on a phone the ‘upload an image’ feature is as indicated here:
Wow, that was easy . Thanks for the tip .
glad the tips worked for you @RedRay - the trick with a different environment is often a case of finding out where the buttons are hidden!
Help - click upload button, select photo, press done, press reply
Nothing happens :thinking:
Tested. It works.
Sorry. All we can tell you is how. we can’t be IT Support, much as we’d like to be.
It’s working, the problem is at this end depending on what file/storage i select the photo from.
