USB connector.
Hi guys. If I buy this, does it just connect to the cable under my seat (V7 stone) to give me a usb connection? I only need the one as never need heated grips etc. cheers.
I’m mounting an SP connect phone charger to the front. Will be running the cable alongside the tank just underneath and cable tying it to what I can. Anyone know if there will be heat issues from the engine?
Managed to just tuck the cable under the tank and tied it off each end with cable ties. Very secure, no issue with the turning etc. having to pack under the handlebar connector as the bars are so skinny! Can’t imagine heat will be an issue as it’s right next to the tank so all I need now is to know if the picture of the plug from earlier is the right one please :grinning_face::+1:.
yes if its the same as a v85, i ran a cable from the underseat socket under the tank and up to my quadlock wireless charging mount, works great. i got fed up of the cable falling out of the worn charging socket (my phone is old)
yes that looks very similar to the v85tt layout, same plug
Brilliant Sid thanks. :+1:
