The tacho on my 1997 V10 Centauro has stopped working. Any ideas as to what has broken, and is it fixable? Thanks in advance.
Has the cable inner broken? Undo it top and bottom and turn one end and see if the other end turns. If it’s not that send the clock to Speedy Cables, they take an age but offer a great service.
Best of luck!
Thanks Chris, I’ll certainly go down that route ![]()
Tacho is electronic, check that the wiring on the bottom of the instrument is still attached, they do fail a cali ev one is a good match👍
oops! Thanks Phil ![]()
Thanks Phil, I’ll check it out ![]()
