anyone tried fitting Ultimateaddon heated grips to a 2024 Stelvio/V1000 ?
i fitted them, they have a good report on other sites. way better than the OEM grips but still not melting my hands - was out in 4degrees today - so probably a minus something with the wind factor - grips ok, good all round warmth on palm and fingers - right hand side is a bugga to fit
I found the same fitting the Oxfords. The throttle sleeve needed quite a bit of filing and sanding down to get it on with hand pressure only. Was beginning to worry I was gonna wear it right through! Took forever it seemed.
