Hi all
Having problems bleeding clutch.
I want to check the slave cylinder.
Can it be removed whilst still in the frame.?
Theres not a lot of space between it & the frame. It all depends on the depth of the slave cylinder.
The clutch slave will probably have a spring in it so when its removed it will push itself out, I had a quick look on the web and the V11 LeMans forum they have an article on it and it did involve removing the rear subframe.
