I find one of my front brake discs is well below min thickness. Any spares out there?
Hi. Is it a V35 -I, II or III? I have a couple of front discs for the I or II, but they dont fit the III
OK. The ones I have are the solid discs.
Bugger! Do you know, are mine possibly from a later model?
I’m new to this…
The one you have pictured is for the later models: V35-III. V50-III and Monza. I have 2 of the earlier ones if needed. If you want to check have a look on www.gutsibits.co.uk under Used Parts and you will see.
All the best
Roger
Thanks Roger, I have drilled discs all round but one of the front was decidedly thinner than the others and way under the limit. I’ve contacted Gutsi bits to enquire. I hope it’s a little cheaper than the steering bearing cup they quoted me on !!
