Quick one. Which coil goes to which side as you sit on the bike?
Cheers.
Assuming it follows the same wiring logic as the big block models, the coil with the green wire goes to the left and red wire to the right coil.
Neil, your bike is a 1978 V35 with electronic ignition? If so the right hand coil has a blue and black wire and the left hand coil a yellow and black wire.
I produce wiring diagrams for most older Guzzis, see here let me know if you would like one for your bike.
Best wishes Chris
Thanks Chris but you have already sold one to me. The wiring to the coils isn’t very clear on mine. ![]()
Whoops! My memory is not what it used to be!
It only occurred to me, could you not trace the HT leads back? Or it just isn’t as simple as that … ![]()
I think that Neil has a box of bits and not a complete bike. But thanks for your suggestion Mike
Well it’s nearly complete but not all in one place/piece…
I found the wires to the coils were the both black but there was a join and after removing some tape the colours you spoke of Chris were uncovered. Hurrah.
Thanks Chris, I forgot … ![]()
