What sort of range should I be getting from full to reserve and then how much should reserve give me?
1979 V50ii
1979 V50ii
Long time since I had it in regular use, but best thing is, you have three warnings: it starts to splutter, left tap(you keep it closed normally), turn ON. Quite a couple of miles, it starts to splutter again, left tap, into RES. Same story again after another couple of miles, right tap into RES. And then… something like 5-8 miles till dry. You know how I know?![]()
I usually reckon on about 140 miles from full to reserve on my my 1980 V50ii, and then about 20 miles from reserve to pushing – a surprisingly short reserve range, and I have ended up pushing it a few times! Having said that, I am running with RamAir foamies and bigger jets, so am probably at the higher end of the fuel consumption continuum.
Thanks. Thats good to know. At least its light! Especially with an empty tank
