I have been unavailable all weekend and I see that a lot of very interesting stuff has arrived on this thread in the meantime. Very interested to see the RiTA circuit diagram, I have never had any experience of one of these and it turns out that all my preconceptions were wrong - well, that’s how it goes. Having had a closer look at the pickups on the Guzzi V50, they also have coils wound on a magnetic pole piece with a rotating steel “lump” on the crankshaft. Presumably this also produces a wasted spark, but it has the advantage that it’s impossible to set the timing 360 crank degrees out, as so many of us have managed to achieve with cam-mounted pickups! Having said that, due to its position etc, it’s still a pig to adjust!
The Morini differs in that it has a rotating magnet and a pickup coil for each cylinder, wound on a laminated steel core. The box of tricks also differs in that it is a SCR-based capacitor discharge circuit. The pulse from the pickup triggers the SCR directly, but has a potential divider, just two resistors to alter the trigger point by changing one resistor, thereby changing the advance range for different models. In practice it makes no difference that I can detect! Once again, these items are 40 years old and are developing some reliability issues. In good condition though, they perform very well. If anyone is interested in the circuit diagram, let me know and I’ll post it here.
Well my conclusion is that I am not going to attempt to modify a Boyer system, though I think it could be fairly easily done. I see no advantage in using old units which have been kicking around my garage, I don’t see why they should be much more dependable than the existing Bosch units. And I’m not going to buy new Boyer boxes. This leaves me two options. Either I’ll live with the Bosch system, warts and all, but pick up a spare box to carry with me (cheap option). Or I’ll bite the bullet and go for one of the modern German systems. Undecided at present!
Many thanks to all for the interesting contributions to this thread!
Joe.
