The brake lever return spring on my V50ii snapped and I have now got a replacement. This might seem a daft question, but the ‘hooky’ end goes under the M/C lever but is the correct place for the other end at the bottom of the cylinder assembly? It doesn’t look right but there is no obvious place for it to go. It’s just peeking out in front of the front mounting bolt hole
I go no access to my Guzzis at the moment, but as for me, and off memory, this all looks good, the spring won’t go anywhere.
Compared to my Monza that is correct
CHRIS
Well, it seems to be OK - thank you both!
Many thanks Fletch. All seems OK now, but charging an issue…
