I’ve got a bit of an issue with my throttle sticking and it appears to be an issue with the twist grip assembly. The cables are new and routes appear good and return springs in the carbs are fine. I’m wondering whether it could be something to do with the two screws on the twist grip assembly, I’ve always wondered what they’re for. Whats their purpose and is there anything else I should check?
Hello Steve
If I am correct which screws you describe, I think they are to put pressure on the cables to hold the throttle open. Try loosening them and it may prove my correct!
Best wishes Chris
