V50ii Alternator testing
My ‘79 V50ii isn’t charging but I have no experience with brushed alternators.
What’s the correct way to test it?
There are a couple of good guides to go through that give you lots of ideas.
Have a look at this
Or this one
1.how do you know that, is red light on or there’s no light but no voltage too when measuring the circuit on running engine? I’d say, on bigger then low revving engines quite popular thing were the rotors, so dismantle brush holder and check conductivity between two copper rings. If nil, then rotor is at fault, not letting red light to go on btw.
