I’m re-building the Lario without a fairing and want to fit a twin headlight. The dominator type twin headlights are 22cm wide but the Lario forks are 179mm wide (across the centres).
You can see I would have a problem with normal after market headlight brackets and they would be too narrow to fit the twin headlights.
Does anyone know of a headlight bracket that would have brackets as wide, or wider, than the fork legs please?
ta
stuart
