Just dragged out the gearbox to sort out a few problems namely, difficult to get neutral and not selecting gears properly ,while it’s out I’d like to change the gear ratio on the primary gears to drop the revs in top to give a more comfortable cruising speed I seem to have 2 options v65 sp 15/22 and v65 lario 16/21 not sure which is going to be better the present ratio is 14/23. anyone have a bit more jnfo.
The primary ratio off the back of the clutch is a speed reduction from crankshaft speeds down to gearbox.
You are quoting standard v50 primary ratio as your current one, if so the SP and Lario will give you more speed for revs.
So if your engine power and aerodynamics let you reach these speeds: SP primary drive will give a 12% increase in speed in each gear, the Lario primary drive will give a 25% increase.
Hi, mate, I did that job on several bikes, first, V50 is no good as shaft diameter is different. Lario 16/21 is same as much more popular Nevada(also Breva750, but Breva despite 17" wheel has a shorter final ratio in bevel box), and mind both N. and L. transfer this long ratio onto 16in wheel(not so sure re Lario?). 14/23 is also used in NTX650 I once had, and I didn’t consider it being too revvy. I think safe option, but hard to obtain, would be 15/22, seen also in Floridas and NTX750. 16/21 may be too long for regular 50bhp V65 engine. And IMO don’t even think about buying just primary gears, buy full gearbox - and then stamp eccentric regulation bolt next to selector fork shaft, play with it - and find how to make gear change more predictable. See some pics. Below the bolt itself:
And here is a whole bunch of pics, but mind, this is V50 gearbox, hence ball bearings, there are roller ones in yours(one of pictures shows V65 gearbox too):
I can get the 15/21 gear set ,but your right a complete box would be ideal but quite expensive and unknown condition so if my box is serviceable should be OK,the issue I have is not going into gear ,more on the upshift, lever moves and returns but doesn’t seem to rotate the drum enough to catch the next gear after a few attempts it will change so thinking maybe the eccentric bolt may want tinkering with or an internal issue but seeing as I wanted to alter gearing I dropped the box out anyway,plus a few jobs elsewhere to fix, namely oil leaks,previous owner had same issues plus neutral difficult to find when stationary.
This all sounds like worn out gearchange shaft, that short one at the rear of the box. Is there a leak from there? Is there a play? If you take a good look at the above pics, you’ll notice how eccentric bolt works, there’s less than half a turn to do full spring movement. But don’t unscrew that to see it as it’s gonna be troublesome to push it back inbetween spring ends.Just have a play on the bench, box in vice, gearchange caught by mole grip.
