V85TT various parts
I’m selling my V85 so am I starting to sell some of the bits n bobs from it.
  1. Titanium Rocker Cover bolts. Set of 6. See Gutsibits part number SSA89291. Used but in good condition £25 posted.
O
2. SW Motech Ion riders footrests. I bought these to fit to the pillion knowing they weren’t quite right. I managed to bolt them on and we went for one ride before removing them. Excellent condition £75 posted.
3. Spare Spokes. 3 of each of three types of spokes needed for the tubeless wheels as fitted to E5 bike (maybe E5+ too, I dunno), plus 4 spoke nipples. All in original unopened packaging. These were expensive for what they are. £50 posted for the lot. Handy and easy to carry as spares if you’re off on a big trip. IIRC 2 of the three types can be fitted with wheel on the bike, the 3rd needs the wheel out and the flange on the wheel for the FD needs to be removed (this is for an E4 bike with E5 wheels).
4. Mistral Velocity Stack and K&N air filter.
Fitted and used for about 5,000 miles. Velocity stack as new, filter, well it’s done some filtering but should be good for 10’s of thousands before it needs cleaning and oiling. AFAIK fits E4 and E5 bikes. £100 for both.
  1. Gear lever. It’s been down the road but only the peg bit is damaged. Could be tidied up a bit or a new peg bit fitted. Keep as spare (that why I held on to it) or for off road use, or whatever. £20 posted.
6. coming soon…..
Tubeless wheel set
Original Heated grips
Touring screen
Very Low & small screen
Mistral Carbon conical silencer
Original top box and mount
Givi top box mounting bracket
Bumot Panniers, brackets and tool box
Hi Austin, I’ll buy the rocker cover bolts.
also how much do you want for the heated grips?
Hi Sid, The rocker bolts are yours then for £20.
Heated grips…. These heated grips are less than a year old as my original set packed up about 10months ago - actually the throttle bit packed up not the heating. I’m selling the replacement set I bought & fitted to the bike in (edited - I found the order) May 2025. Done maybe 4,000miles, so next to no wear or anything. £125 posted with the rocker cover bolts (to be clear that is the £20 + £125).
They are currently on the bike so I need to remove them and check the original non-heated ones work still - can’t see why not. But….i am maxed out busy all this week, so I can’t even start to remove them until next week. Let me know if you want them and I will message you
While I’m removing the heated grips I will also be removing the OEM led fog lights and mounting brackets. These will be in a future for sale advert too.
Hi Austin,
I’ll send you a message, yes I’ll buy both.
Too late for the rocker cover bolts, dammit. Still - let me know a price if you ever split the Mistral velocity thing and the filter. OEM fog lights and brackets might be interesting, too!
Ok then Mr Inspector, I will split the mistral velocity stack from the K&N. The air filter will fit my Griso so I’ll keep it for that to install one day. Umm, say £85 posted.
If you want the fog lamps say so and I’ll definitely take them off next week. I seem to remember a small bit of Aluminium oxide on one of the bodies, it’s underneath so not easily visible and easy to patch up. Both working as if new. Top quality kit. Plug and play. But they ain’t cheap. I’ll have a look and put a price on them.
Yes to the velocity stack. Looking at the price of the (new) fog light kits I’ll probably save my pocket money! Send bank deets for a swift transfer.
Rocker cover bolts sold
Heated grips sold
Velocity stack sold
Brake lever sold
I think that’s it for the items on this thread.
