Wheel bearings, Spada
Hi All.1981 Spada, cast wheels. What’s the method for removing the bearings?Thanks,Geoff
should just punch out with a drift or old screwdriver
Heating the surrounding area with a heat gun or blowlamp can help but can also damage paint.
That’s what I thought but there’s almost no clearance between the bearing spacer and the edge of the bearing.
Another method is to get a suitable sized rawl bolt and expand it in the bearing you can then use this to drive it out with a punch placed centrally.
Just get a big screw driver in there,Pull sideways and the spacer will move over.Then knocker the bugger out tapping on oppersite sides of the bearing.
Worked for me anyway. I used a tommy bar as the drift.
