I want to fit some oxford heated grips to my V85tt.Is it just the usual standard fit ,as the dealer told me that it must be the Guzzi ones due to the throttle control.
Would anybody have the pin out connection for the spot light connector underneath the tank, as I want to use the original switch.
          Hi, I’m fitting the Oxford grips as you did. Can you tell me does it matter what colour goes to which, has in blue or brown to red on the Oxford grips. Thanks in advance.
Blue is earth on Guzzi ( i think this is a DIN rule for european vehicles)
So i put black to blue in case Oxford have assumed red is power and made it more insulated than black
Thanks, sorted
