In the process of checking tdc on my newly acquired T3, I have managed to drop a 2” piece of pencil down the spark plug hole (doh!)
Other than removing the cylinder head (which is probably a bit beyond my ability - mind you, it’s never stopped me before), does anyone have any suggestions?
Ones that currently spring to mind are:
Squirt fuel into the spark plug hole and burn the pencil.
Start the motor with the spark plug out on the offending cylinder (I don’t like the idea of bent valves with this one!)
Just fire it up and see what happens (I tend not to be lucky like that).
Get out the manual and remove the head (you know it makes sense).
Find a bit of soft bore hose that just fits thru spark plug hole and tape it to the hoover/dyson, it might hold the pencil the wrong way, or you get lucky and it grips an end !
The saga continues: I tried coaxing, prodding and hoovering the offending object to no avail. So I decided to man-up and remove the head
Surprisingly, everything was going quite smoothly until I got to the 6 bolts holding the head together. The top one has a cap with an Allen key fitting. Regretably, mine is quite rounded and won’t budge.
In these circumstances, when I find myself reaching for the Mole grips and big hammer, I have learned from bitter experience to STOP and put the kettle on.
YouTube suggests heat, cold chisels and other WMDs. I am a bit wary of applying heat as I don’t want to damage the head.
Does anyone have any sage words of advice when faced with this issue?
Also, favourite sources of good quality parts? I am aware of Gutsibits, but few others (as I am relatively new to returning to the fold). Am going to need a few gaskets, etc, and a new bolt cover after I’ve removed this one!
I see your point but, according to my Haynes manual, the hex is just a cover, so I don’t think it does anything to secure the head.
I’m having dark thoughts about reaching for the impact driver. I don’t think I have a suitable ‘bit’ for it and don’t really want to cause more damage by guessing what might work at this stage.
You’re bang on up to date.
Giving the civer a gentle tap around the perimeter and then inserting the Allen key and giving it a couple of sheep taps may help break the seal.
Next step.
You make a spacer strip from thin
metal. A drinks can will do of you get stuck. Put this over the end of the Allen key a tap it home. There’s a good chance that this will give sufficient purchase.
At the risk of grandmother and eggs……when you have the key firmly in place lean as hard as possible over the key at 90 degrees.
