I’m sorry this is so long! I’ll try to edit it down. Thank you if you manage to read to the end.
This is related to the thread entitled “Clutch/gearbox adjustment V100” but I want to take it in a different direction so I feel justified in creating a new thread.
I have a new V100S, and have one negative observation: the clutch drag is terrible! The most obvious symptom is the horrendous bang and jerk when selecting 1st gear from standstill. Of course almost all bikes with multi-plate wet clutches do that to some extent, but in my 51 years of motorcycle ownership the Mandello is by far the worst. The other symptom is the extreme stiffness when going down the gears at very low speeds - say less than 15mph. 4th to 3rd is pretty stiff, but 3rd to 2nd is sometimes so stiff I’m genuinely afraid I might break something because of the pressure required on the lever.
Getting into neutral from 2nd when stationary is similarly difficult. Mine has the quickshifter; when pressing down for neutral, the spring-loaded switch in the link rod compresses, and as soon as the gearbox moves out of 2nd gear, the pressure comes off the link rod, which then expands and pushes it straight through into 1st. MG obviously found this themselves because they fitted a device in the gearbox which prevents it from selecting 2nd gear when stationary. If it wasn’t for that you’d be shifting back and forth between 1st and 2nd with no chance of finding neutral.
Now, before my idea/question: yes, I know the clutch and gearbox are supposed to free up as the miles go on. Yes, I know some bikes seem worse than others; and yes, I have the clutch lever set for maximum span. The clutch drags even when the lever is hard against the handlebar.
I’ve recently seen a video review of the V100 Stelvio, and it uses the identical engine except for one component: the clutch.*
MG say the clutch has been completely re-engineered to improve the overall feel and behaviour when changing gear. It is a slip-assist clutch, and interestingly, it now has a cush drive built in. This suggests that MG are concerned about the violence of the engagement and have included the cush drive to mitigate it.
The fact that the Stelvio has this new clutch suggests to me that they know the Mandello clutch is problematical. If I’m right, I’m willing to bet that the Stelvio clutch will appear in the Mandello when it comes to the first model refresh. We’ll see. I’ve looked at the parts diagrams for both engines, and it appears that the Stelvio clutch could indeed be fitted in the Mandello with no changes apart from one or two spacers adjacent to the clutch.
After that lengthy introduction, my question: how can I explore this further? Will the Stelvio clutch, in fact, fit the Mandello, or am I wrong about that? Has anyone else thought about this or explored it? How can I ask MG about retrofitting the Stelvio clutch in my Mandello?
The agricultural behaviour of the clutch and transmission takes the edge off the bike, in my opinion, and seems out of place for a premium, £17,000 motorcycle. I wish it had a gearchange as slick as pretty much every Japanese bike has had for years.
Thoughts? Comments? All welcome, including violent disagreement! ![]()
(* Apparently they have also strengthened the engine casing to handle the stresses of off-road use, and I also believe they might have modified the gears themselves.)
